Lignocellulose compositional analysis
Posted: Mon Oct 11, 2010 7:24 pm
I hope my question is not outside the scope of this forum. I am trying to run a protocol for compositional analysis of lignocellulosic samples (wood) (it is the NREL or ASMT protocol for structural carbohydrates analysis in wood). It involves a two stage hydrolysis of the biomass with concentrated and dilute sulfuric acid, and analysis of the sugars produced by the hydrolysis of cellulose and hemicellulose, on a Pb sugar column. My HPLC seems to be working fine, as I get good results when measuring samples from pretreatment and enzymatic hydrolysis experiments of the wood samples. However my results for the compositional analysis of the solid samples lack both accuracy and reproducibility for the same biomass type. Values measured are always lower than expected which might mean that there is loss of sugars somewhere, or perhaps an incomplete hydrolysis.
Should anyone have any experience with this type of analysis I would appreciate your comments.
