QTrap 5500 LC/MS/MS Tuning Variability
Posted: Sun Oct 10, 2010 7:48 pm
Would anyone have any insight into the possible causes for obtaining two
significantly different MW tuning results between Mass Spec Instruments?
Say the MW I am looking for is 170
(using +1amu on both instruments with the same gas/temp levels..etc..)
also using the same infusion solution...
On one Mass Spec I can see 171
On the other Mass Spec I can only get 172...+2amu greater
I am thinking the second Mass Spec is out of calibration...but I am wondering if there could be any other causes..
