Connecting Varian 9050 UV-VIS detector to Ultimate3000HPLC
Posted: Thu Oct 07, 2010 1:20 pm
by Kazimierz
I need connection of Varian 9050 detector to Ultimate HPLC system via UCI-50 Dionex Interface to be collecting data under Chromeleon.
This is virtually was connected from HPLC side, but I do not have
cord ending to the Varian detector. From where I can buy such ending and
what is the english name of such part.
Posted: Mon Oct 11, 2010 5:00 am
by Alex J
Do you have the cables that came with the UCI-50?
Most detectors have an analog out connection to record the signal and also an auto zero input connection.
Alex
Posted: Mon Oct 11, 2010 1:22 pm
by Kazimierz
Dear Alex,
The servicemen have attached two additional data transfer cords
(one Shimadzu RF-551 spectrofluorometric detector as well as to
Varian 9050 UV/VIS Detector - using CH1 and CH2 inputs respectively.
Ultimate3000 is connected using one USB input/output cord
The Shimadzu working very well because it have possible outside ways
for connection, without the ending: black-is shield: pink-is analog high+;
and gray- is analog low-. The both cords was taken from original
ULTIMATE3000 service spare parts shipped with HPLC: QC 8911 0001,
P/n 6000 1004 but both don't have any endings.
Varian 9050 UV/VIS detector have both identical outputs 1 or 10 V
dedicated for external DATA SYSTEM OUTPUT and for RECORDER OUTPUT,
respectively.
I need one ending of 3 fibers to be connect detector to Chromeleon.
sincerely
Posted: Mon Oct 11, 2010 11:56 pm
by Jason Wmson
Sounds like you need a cable from Varian that would plug into the detector output.
That cable would be spliced onto the Dionex UCI cable.
