Software to View/integrate Chemstation files?
Posted: Thu Sep 30, 2010 3:58 am
by Lisan
Hi everyone
I'm wondering if anyone knows of a program that can read Chemstation data files. My problem is that I can't install the version of Chemstation that I have on my current computer (Win7-64) so now I can't access the whole data set for my thesis. Unfortunately I don't have access to any other computer with an older OS so the only solution I see is if there's a chromatogram reader or such available for 64bit systems that can do it. I've googled but can't find anything so now I was hoping that all the experts on this forum would have some ideas for me.
Any ideas that don't cost a fortune are greatly appreciated!
Posted: Thu Sep 30, 2010 4:09 pm
by Schmitty
Do you have access to Windows 7 XP-mode? Tha may allow you to install Chemstation.
Posted: Thu Sep 30, 2010 4:29 pm
by Lisan
No unfortunately I have the Home edition so it doesn't let me do that.
Posted: Thu Sep 30, 2010 8:39 pm
by Cmdr Keen
Don't know if it might work, but have you thought about installing Oracles Virtual Machine Software and install a virtual WinNT or anywhat OS?
Posted: Thu Sep 30, 2010 8:56 pm
by Lisan
No I didn't even know there was such an option
. I will definitely look into that. Is it complicated? Like requiring a software engineer or the like.
Posted: Sat Oct 02, 2010 8:23 pm
by Cmdr Keen
installing VM ist not very complicated when it's just about installing a program on a virtual computer. It get's rather difficult if you want to use network, usb or anything. There's a huge Wiki for Oracle VM, it should answer most questions. The installation itself is a step-by-step programm which can also be used by non-software-engineers (like me)!
Posted: Wed Oct 20, 2010 10:33 pm
by mardexis
If you are a recent grad student then perhaps you like things inexpensive, tedious and time consuming. You can export the data (if you can get access to chemstation) as ascii and plot it using excel.
Posted: Tue Oct 26, 2010 7:01 am
by eselmeister
Hi Lisan,
I've written an open source
ChemStation alternative called
OpenChrom:
http://sourceforge.net/projects/openchrom.
A ChemStation file import converter is also available (I've decoded the binary file format ... it was a funny work). You can install it as a plugin afterwards, see:
http://www.openchrom.net/plugins/converter/agilent.
I know, the software needs a lot of improvements, but it's a beginning. It is available for several operating systems and architectures, also for 64 bit systems. It hopefully helps you.
Posted: Fri Nov 12, 2010 8:35 am
by orcicdejan
Re: Software to View/integrate Chemstation files?
Posted: Wed Mar 02, 2011 3:58 pm
by Shewy
Hi everybody,
So in order to run Agilent MSD Chemstation E.02.00.493 on a Win 7 remote computer :
- Install first the win xp mode from Microsoft :
http://www.microsoft.com/windows/virtua ... nload.aspx
-Follow the win configuration protocole from Agilent :
http://www.chem.agilent.com/Library/use ... _ebook.pdf
-Than follow the installation protocole for the CHemstation software :
http://www.chem.agilent.com/Library/use ... -90064.pdf
Don't forget to configure your system in the MS configuration box as a remote one. whereas the software will crash because he won't find any GC or MS connected to the laptop.
Hope that could help somebody as i pass a weekend in order to get it running.
And a supplemental question about the opensource equivalent : Is this open source software more intuitive to use and more handy than this CHestation bullshit...does anybody have an experience using it ?
Thank's et Allez hop cascades comme on dit par chez nous.
Posted: Wed Mar 23, 2011 8:00 pm
by Heva
Do you know anyone running Empower? It has a data convertor to read import and then process Chemstation files.
Posted: Wed Mar 23, 2011 8:07 pm
by Heva
I also heard of a viewer called Inspector once. I think you can read Chemstation files with that viewer. Try Google with Inspector jcamp and chemstation...should find it.
Posted: Tue May 10, 2011 6:46 pm
by antonk
Our UniChrom allows reading and processing .CH data (all versions) for free.
http://www.unichrom.com/chrom/uc-ffe.shtml
If your file can't be read - please inform our support.
Posted: Tue Jul 13, 2021 1:14 pm
by mosman
Hello Mr. Eeselmeister
I really appreciate your great piece of work 'OpenChrom'
I'm in urgent need of the "Agilent import converter plugin for Openchrom" but could not find it anywhere.
Thank you in advance
Kind regards,
M. Osman
Hi Lisan,
OpenChrom:
