Usability and annoying things in Chemstation
Posted: Sat Sep 25, 2010 8:05 pm
last week we got our fast scan upgrade for the 6890/5973N and with it came a new WinXP-computer which replaced the old NT4 machine. With this came the latest version of ChemStation.
Up to now I used the Chemstation only for getting the raw data, all quantitation and MS search was done by exporting into AIA-format and working with the software of another machine.
Now, after the upgrade, I want to work with chemstation again but there are several annoying things that don't make life easier. I'm wondering if I'm too stupid or Chemstation is... normaly I won't consider me as a PEBCAK
Maybe one of you can give me hints or workarounds to some of the following points:
1) This is rather cosmetical: When I click onto a peak and let display the mass spectrum, the masses are shown with 1 digit after the decial point. From a scientific or technological point of view this may be progressive but I'm used to integers and have a trained eye on integers. Thus it's more difficult for me to recognize a common spectrum without library search. Is there a way to setup the mass number view? Maybe even in some configuration file?
2) Most chromatograms are screenings of unknown material or unknown contaminated materials. So I'm not working quanitative in most cases but I have to have a close look to every peak, even those with low integrated area. Often huge peaks are not important to me 'cause their existence was expected and is not of interest, but a contamination (a small siloxane peak e. g.) is of major importance.
The autointegration mechanism of chemstation is not very useful for this situation because I won't get the peaks of interest with threshold setup and it would take a lot of time to integrate all peaks of interest by timed events. Only way here seems to be manual integration. So my question is: Is there a way to securely store manual integrations to the data/method file, maybe including annotations? They are important for me and the customers because concluding "substance a and b is included" doesn't make them believe, I have to show it in the chromatogram by a text or number annotation.
3) When I make annotations (well aware that they will be not stored [why ever]) and I want to copy the annotated chromatogram to the clipboard, there are several possibilities in the software. So far so good. But goodness ends if I paste it in excel, word or a graphic processing programm. The Chromatogramm is there, the annotations too, but they are not at the same place as they were originally. There's always a more or less big shift in x or y direction of the axis. Apart from that the font for the abundance and time axis looks awfully distorted. I can correct that by enlarging the chromatogram into one direction but is this the only solution?
I know, I could make a screenshot in Chemstation, but it's annoying to edit that screenshot everytime in gimp and cutting away everything that hasn't to do with the chromatogram.
4) is it possible to display a chromatogram with only (manualy made) annotations WITHOUT retention times? Displaying retention times is confusing non-chemists and gives too much information about analysis to the competitor...
5) In the software I used up to now (Shimadzu) it was possible to integrate the <selectabe number> highest peaks in the chromatogram. Is there a similar possibility in Chemstation? Or is there a (theoretical possible way) to write a macro performing that task?
6) Are there any chemists out there who don't do routine analyses and perform screenings? Am I the only person with that problem? I feel a little bit lost. I'm well aware that Chemstation was not designed for such usage but after decades that software exists I think it should have been achieved by agilent to design the software into that direction as well - not only since screening is wide spread too in the meantime...
Thanks for any hints,
Commander Keen
Commander Keen
