Problem with first run sample of the day
Posted: Fri Sep 24, 2010 9:36 pm
Hi all,
I'm totally new to this forum - some very interesting topics for me to delve into but firstly I was hoping for a little help from someone far wiser than I!
I'm working on a Shimadzu QP2010. I'm having a strange problem where, the first run after any down time is plagued with siloxane peaks at the end of a temp programmed run. An identical injection immediatly after this is clean. My baseline curves up at the end of every run regardless. I'm running at 30oC for 0.5min then 45oC/min up to 340oC with a hold of 1 min at the end.
It confusing me as to why this is only appearing in the first run. So far I've tried new column (baked at isothermal temp), new septum, liner, cleaned ion source. I'm thinking either the temp programme is a problem or the carrier gas (helium).
It's worse on the first run after being down overnight but have noticed that even an hour of sitting, I am still getting these peaks.
So I guess my questions are:
What is causing this?
Any thoughts on how to get rid.
I realise you may need more info so please just ask. Many thanks in advance.
