separating a peg-lated weak base 10K da
Posted: Fri Sep 24, 2010 7:58 pm
Hi guys,
I'm trying to purify components in a mixture that comes from the preparation of a PEGylated small molecule with amide, and amine functional groups.
The column is an apHera C8 Polymer column.
mobile phase A is
20% 8mM octane sulfate salt / 20mM PO4 buffer pH 6
60% ACN
20% MeOH
MP B is
70% 8mM octane sulfate salt / 20mM PO4 buffer pH 6
10% ACN
20% MeOH
The gradient is something like this
5%B 0min -----5min ramp---->55%B 0min ----20min ramp---->60%B 0min ----8min ramp--->95%B back down to 5%B to for next inj.
resolution of the many peaks is horrible and they all seem to come out around 23min.
My questions are
Does anyone else think using acetonitrile instead of MeOH to increase organic is a bad idea? shouldn't ACN be used more like a modifier with IPR?
Is a gradient a good idea since all components elute within ten min of each other?
If I want to increase resolution should I use a slower gradient which starts at a higher %B in the beginning instead of going from 5% to 55% in five minutes?
Is there a reason for this fast gradient that I am missing? I have seen these kinds of gradients used when separating things like insulin but never understood why.
The reason I ask these questions is because I have done IPR separations before but with small molecules and on a Si based column. I'm not sure how using a polymer column changes how well the IPR will coat the column.
I hope you find my questions interesting since there are many.
mobile phase A is
60% ACN
20% MeOH
MP B is
10% ACN
20% MeOH
My questions are
