Solvent for Dissolving Gums
Posted: Fri Sep 24, 2010 2:41 pm
by Dressage
I am attempting to analyze a compound (via HPLC) that is in a product which contains gums (iota-carrageenan, xanthan, and locust bean gum). Does anyone have suggestions of a good solvent that I could use to break down/dissolve the gums so that I could extract the active?
I've done a bit of research and ran into chloroform and hexane as possibilities.
Thanks in advance. :)
Posted: Sun Sep 26, 2010 8:13 pm
by unmgvar
this strongly depends on your compound of interest characteristics and method of separation
dissolving in chlorform hexane with no other steps means going for a normal phase method in HPLC most likely. is it suitable?
you could do a liquid to liquid extraction or SPE, again depending on the nature of your compound
Posted: Mon Sep 27, 2010 12:13 pm
by Phycal
The problem with many gums is that if you disslove them, they usually thicken up the solvent. That makes them hard to inject then. Is there a way to extract the compound from the sample, leaving the polysaccharides behind?
