Basic Questions about Gas Chromatography
Posted: Sun Sep 19, 2010 4:09 pm
Hi!
I am a fairly young student who has just basically been exposed to the world of Gas chromatography
I have a few basic questions:
If a GC is equipped with a thermal conductivity detector and the temperature is increased from lets say 60 to 70, would the observed peaks on the integrator be sharper and take less space to be drawn? Is the reason behind this because if the temperature is higher, then the sample you inserted evaporates faster?
Vice versa, if temperature is decreased from 60 to 50, then the peaks drawn would be fatter right? For example if water was in the sample inserted, the peak of water would be very fat, since the boiling temperature is so high?
Also what is the general effect of increasing and decreasing sample sizes? From lets say .6 microlitre to .4 microlitre, or .6 microlitre to .8 microlitre?
Thank you guys! Please try not to make fun of me for these basic questions
