Dionex AS50 'no vial detected' problem
Posted: Tue Sep 14, 2010 8:46 pm
Hi all,
I am constantly having trouble with the Dionex Autosampler which keeps giving me the 'no vial detected' error message. I do have a vial in place though...
I noticed that there is a component on a small board on the needle arm which has an optical sensor where something slides in and blocks it or leaves it unobstructed. The metal part that slides in this component goes down to the vial and rests on the top of the vial.
The injection port alignment by the way is properly done, and all other functions of the autosampler seem to work properly.
I assume it is the vial detector's fault in some way, but I could also be wrong.
Has anyone faced a similar problem or has an idea on how to work on it?
