Cocamidopropyl betaine Analysis by HPLC
Posted: Tue Sep 14, 2010 2:19 pm
I am trying to develop a method for CAPB using HPLC with ELSD Detection. I am using an Acclaim Surfactant Column, with Methanol and Ammonium Acetate buffer as mobile phase. As diluent i am using a 80:20 mix of Methanol and water. The ELSD parameters i am running are gain =6, temp 40 deg C, flow 1ml/min, with gas pressure not exceeding 3.5bar. However, no mater what ratios i run the MEOH and buffer at there is a huge peak that keeps splitting around 2-3 retention time. Is there any suggestions anyone could give in order to separate the CAPB from the sample. Thanks in advance for your time and consideration.
