Chemstation: manual integration and mass specs
Posted: Fri Sep 10, 2010 2:44 pm
I'm new to chemstation and have to do a lot of manual integration with screening analyses. I must have a closer look to every major peak in the chromatogram and its mass spectrum / search result to decide wether it's important for my analysis or not.
The only way to do that is manual integration mode which I can select at "Tools -> Options -> Manual integration".
When I integrate manually, is it still possible to have a look at the mass spectrum of the peak I'm integrating at the moment? Normaly I do this with a right mouse double click. After that comes the NIST search with a second right double click in the mass spectrum.
But in manual integration mode the right mouse double click doesn't work.
Does anyone know how to solve that problem or please tell me how you manage it to work time-efficient with that software when performing screening analysis.
Thanx,
-Keen
Thanx,
-Keen
