75% methanol in water using phosphate buffer Ph=3 , 25 mM ?
Posted: Wed Sep 08, 2010 11:02 pm
Hi , Tom and every one
Is my preparation correct ? :
Buffer preparation : in 1L volumeric flask put
1- 50.00 ml of 0.5 M tetrasodium pyrophosphate
2- 57.75 ml of 1.00 M phosphoric acid .
Fill up to 1L by water .
so now 75% methanol in water with buffer of phosphate at 25 mM can be done as the following in 900 ml flask :
675 ml methanol was put in 900 ml flask + 225 ml fromthe buffer that was prepared in 1L ( because i want to be buffered at ph=3 ).
Any help will much appreciated
