columnbleeding
sometimes I have problems with column bleeding :? . I don't understand why: I couldn't find a leak and there's a carrier gas cleaningcartridge installed, which looks like a new one after 6 month in use.
Any idea?
Beate
Column bleed ? which kind of phase, not all are the same.
components you have injected upon a column may slowly bleed off with later use,
strong bases may react with silicone phases and cause bleed.
oxygen in carrier gas (cleaning cartridge - carbon trap? ) will cause silicone phases to bleed.
exposure to oxygen during storage (not sealing the column ends) will also damage the phase and cause bleeding.
Take care of your columns.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
