separation of unknown water soluble compound
Posted: Wed Sep 08, 2010 1:05 pm
by Thwee
I hv some unknown water soluble compound need to be analysed..but i hv no idea what shld i start with?can i use hplc and reverse phase C18 to separate them? what solvent system need to be used? thanks..
Posted: Wed Sep 08, 2010 1:49 pm
by yangz00g
If they are unknows, what's the reason for you to seprarte them? For fraction and identification? preparative LC?
Posted: Wed Sep 08, 2010 1:59 pm
by Thwee
because they hv some antifungal activity and i wanna identify what is the compound present..
Posted: Wed Sep 08, 2010 3:42 pm
by Gerhard Kratz
If you have MW more than 1000 Da and difference in MW is 500 Da you can separate them also with SEC on a silica based SEC column.
Posted: Wed Sep 08, 2010 3:54 pm
by mardexis
If they are unknown and you want to know what they are you probably need some mass spectrometry.
Alternatively, you might try RP HPLC. Run a wide slow gradient with low UV monitoring and see if you get some peaks. Collect each of the peaks you see and test each one for activity. If you see activity with one of the peaks you could look at ways of identifying or send out to a lab specializing in this.
RP-HPLC
Posted: Wed Sep 08, 2010 4:09 pm
by lcrandall
Hi
I would start with reverse phase HPLC. You can either hire a contract research company (like mine! :) ) to do the preliminary method development for you.
Or, an affordable option would be to contact a column manufacturer, provide information about your compound, and use their suggestions. Column makers have very good knowledge about their product and can steer you in a helpful direction.
