Negative peak in HPLC
Posted: Wed Sep 08, 2010 3:23 am
Instrument : Shimadzu SCL-10A system
Column : Supelcosil LC-NH2 250 X 4.6 mm\
Flow rate : 1.2ml/min
Temp : 30
Detector : RID 10A
Mobile phase : 75 : 25 MeCN : ultrapure water
Diluent : 75 : 25 MeCN : ultrapure water
I'm using this system to detect d-sorbitol. After the solvent peak, a negative peak appear just after d-sorbitol peak. This negative peak is absent when I ran the system in Jan.
This negative peak is absent when I inject the mobile phase.
Temp : 30
Detector : RID 10A
