FAME analysis-------------abnormal peak broadening
Posted: Thu Sep 02, 2010 11:44 am
Dear Colleagues,
I ahve a peoblem with FAME analysisi with GC-FID.
Peaks become abnormaly broad somehow suddenly, and I cannot get it solved back to normal state.
Small description:
1) FAME peaks become very broad with Shark fin shape front shoulder. And it goeas as a system, where higher the carbon number larger the broadening. Solvent peak (hexane) is very normal.
2) Changed several columns and teh effect remains.
3) Cleaned all what is possible - FID, SPL. Changed liner, FID nozzle.
4) Run another kind of sample - some alcohol mix and alkane mix. all is normal.
5) Done splitless analysis to eliminate assumed split valve defect. Nothing much changed.
6) As there are to FID's on instrument checked with second with seperated electronic gas controler, same problem remains.
7) Checked the same sample and same column on another but same model GC, all is working.
It seams that somewhere and somehow some kind of specific adsorption causes a problem. But how it was working for few years without problems?
Maybe someone has any kind of similar problems with FAME's? Or know any trick how to check wether it's detector or injector problem.
thankyou in advance
Zydrunas
Small description:
thankyou in advance
Zydrunas
