Issues with Reinstallation of ChemStation A.08.03
Posted: Fri Aug 27, 2010 6:55 pm
This particular group at the university had been running an Agilent 6890GC through a Win NT workstation. Hard drive crashed so it was replaced and Windows NT 4.0 (SP6) was re-installed, along with the drivers for the LAN card.
Upon trying to re-install the ChemStation (G2071AA), one gets the error "An online core must be purchased in order to install additional intrument modules". Click okay, program closes and nothing happens. Only thing I found related to this was that "Most probably, a previous version of the Agilent Chemstation was installed on the PC, but the CHEM32 directory subtree was deleted before setup. CHEMSTATION.INI still contains references to the deleted Agilent ChemStation installation in the [PCS] and [PCS,..] sections." Obviously refers to a different version of Windows and ChemStation but still, it's clearly not the case here since the hard drive was formatted (no references in the Win.ini file either).
Any thoughts at all would be appreciated - we're at a loss!
Roxanne.
Roxanne.
