MTBE
Posted: Fri Aug 27, 2010 9:00 am
Hi there,
newbe here, we intend to analyze the common oxygenate such as methanol, ethanol, ether, DME etc from MTBE. To complicate the matter further there are C2,C3 up to C6 present in the matrix. I'm thinking of the following configuration basically col1, DB-1 (25m*0.53m) to strip the HC, Col2 Rtx-1(60m*0.53) to isolate the MTBE from the component of interest and col3 GS-oxyplot(10m*0.53) as an analytical column to separate all the oxygenate.
Question will this one work?
Is there another easier/faster route?
Cost is a secondary factor here.
Plumbing diagram is attached below, just click to enlarge.
Thanks in advance for any help.
Rgds
KAE
Rgds
KAE
