SPE Autotrace
Posted: Thu Aug 26, 2010 2:33 pm
Hi
I am not sure if this is the correct forum. I am looking at analysis of chlorinated pesticides PCBs and PAhs in a sedimetn sample. I have extracted the sample usign the Dionex ASE system. The solvent is 100% DCM. WOuld this solvent be acceptable to extract all the above components.
I also want to do a cleanup and fractionation using the Dionex Autotrace system. The samples are to be analysed by GC/MS. I was hoping to use a standard 1g/6ml silica cartridge for cleanup/fractionation.
Can anyone guide me on this process.
