Is there a way I can save my manual integration events for individual signals without using batch mode? I understand that when you save manual integration events, you're actually modifying the method file, but I don't want to do that. Often times, while I'm running a long sequence, I like to start analyzing the signals that have already run so I don't have as much to do after the sequence finishes.
