how to get rid of peak shoulder? Help please
Posted: Thu Aug 19, 2010 3:29 pm
Hello every one,
i am trying to develope HPLC method for B carotene. there is a good peak on chromatogram but peak has a shoulder and i am strugling to get rid of it. In following link If you see the peak shoulder for peak MDA 3.650, my problem is pretty much same as shown in figure though in my case i dont have 2 peaks.
Chromatographic conditions i use are;
Mobile phase: Methanol: dichloromethane (75:25)
Flow rate: 1.8 ml/minute
Detection wavelength: UV-absorption 450 nm
Temperature: 40C°C
Injection volume: 20µl
Run time: 10 minutes
Retention time: 5 minutes
Column: Agilent eclipse XDB-C18, 5μ Particle size, 4.6 x 150 (L x ID mm)
It will be very helpful to know how can get rid of shoulder peak or if that much of peak shoulder is acceptable
Thanks in advance
Temperature: 40C°C
Thanks in advance
