Larger than usual Column Fittings
Posted: Tue Jul 27, 2010 9:54 am
Hi all,
I have this old chromatography column I would like to test but I notice it does not have the usual fittings. They are somowhat larger similar in size and thread to the 1/4" tubing low pressure fittings. Has anyone seen such fittings. Where could I find some to use with the normal 1/16" tubing?
The column is a Dionex CS-4.
