New to MS - Need HELP!
Posted: Wed Jul 21, 2010 4:14 pm
Hello. I am new to practical MS work. I have taken some courses about theory and data interpretation but do not have much real experience running the mass spec to obtain the data.
I work for a small company and we have an old Sciex API365 that I am in charge of getting up and running as well as trying to obtain data from. I have cleaned it and have it running but now I need some help from there.
At this point the work I would be doing would be direct infusion of a single peptide soln or a collected fraction using ESI-MS. My samples are typically dissolved in 10% ACN / 90% H2O. Do I need to add some formic acid before i do the direct injection? If I am just using "generic" ESI parameters, would I still see a signal even if the parameters are not optimized?
Any suggestions would be appreciated. Also if anyone has any suggestions on books that might be helpful to someone very new to the practical aspects of MS, I would appreciate that too.
Thanks!
Thanks!
