Low GC Signal for MeOH std run
Posted: Mon Jul 19, 2010 12:26 pm
I am using a HP6890 Series GC. I am currently using a Porapak-Q column, using a FID detector.
Recently there have been several problems with my Methanol standard run. Originally, there was just bad tailing as the tailing starts at the mid of the peak. Then, i have sonicated the FID jet, the collector body and its insulators. Then I started conditioning my column again. The signal would go up till around max 70 and after igniting and increasing our column temperature, the signal will go to as low as 2- 4.
I'm not sure what's the cause of this as I have checked the injector, the liner and fid jet.
