HP7694 carousel adjustment
Posted: Thu Jul 15, 2010 8:57 pm
Our 7694 Headspace sampler carousel is out of adjustment. According to the manual I have, it's says to "call Agilent service"...
In the past I have adjusted the optical sensor position under the elevator area, but I did that Monday and it's back in my shop out of alignment again after only 10 to 15 vials through it. (I don't have service manuals/schematics, nothing appears to be loose, the belt is tight, does not appear to be excessively worn, but maybe it should be replaced...???) Right now I'm at the end of the adjustment for the optical sensor.
The 7694 is needed "yesterday" so am hoping someone here knows the proper alignment procedure or other suggestions.
Thanks!!
dersh.
Thanks!!
dersh.
