Analysis of 2-(dimethylaminomethyl)-cyclohexan-1-one
Posted: Fri Jul 09, 2010 7:34 am
Can Anyone help me on the analysis as well as stability of 2-(dimethylaminomethyl)-cyclohexan-1-one . this compound is heat sensitive and give the impurity when heating at above 50°C. But at present i have the analysis of this compound on DB-225 Column. I got the results repetable but the stability of the Compound in Various Solvents not getting ( Slovents are ( MDC,MeOH,Toluene,EDC,CHCl3,IPA,Acetone).
My First question is : is this compound is suitable to analyze on GC
If yes then please explaine IS there any possibility of unstabilityof this compound in these solvents.B'use when i analyzed this always freshly then i got the same results but if the solution is prepared and then continuously check the stability of this solution after Every 2.0Hr. then got the one peak is increased with time. this will happened in MeOH,MDC,EDC,Acetone and in toluene this will increase very slightly.
[/list]
[/list]
