extra GPC peak Dialysis tube
I see negative peaks which come out aftre my main peak in the GPC chromatogram ( RI detector) in case of my dialyzed samples but not the non-dialyzed ones. I wonder whether these peaks may stem from dialysis tube? ( cellulose tube, 12 kD)
Thanks in advance
What you see is probably the total inclusion volume/disturbance.
The dialyzed sample solution is more different from the mobile phase than the non-dialyzed solution (the dialysis has removed the majority of small molecules from the solution). Actually this is more usual than cases with no negative peak at the total inclusion retention time.
In total there are 54 users online :: 2 registered, 0 hidden and 52 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 52 guests
