Chemstation A with Windows XP
Posted: Tue Jul 06, 2010 8:09 pm
Hi all,
According to this compatibility chart http://www.chem.agilent.com/Library/Sup ... a10674.pdf, Chemstation A.09.03 is not compatible with Windows XP. However, I have defied the compatibility chart and am successfully running it on XP Pro SP3 with no apparent problems.
My issue concerns a second computer controlling a second 1100, which is officially on its last legs. I was going to replace it with an XP machine and load Chemstation A.09.03 onto it, simply because it worked before.
But before I do that, I was wondering if anyone else has had any experience (ranging from minor problems to epic failures?) running Chemstation A's earlier versions (earlier than A.10.0x) on XP?
Thanks!
KS
Thanks!
KS
