i am not chemist i need help in IS PLEAAASE
Posted: Mon Jul 05, 2010 12:13 pm
Hi guys ,
I am not chemist that why i struggle
I have very simple question as i search the net but nothing give me step by step how to do internal standard calculation ( because i am not chemist originally and this is my first time with this CALCULATION AND PREPARING THE CURVE ? so please help me otherwise i will cry
i have three unknown analytes ( analyte 1 , 2 and 3 ) in my filtered solution of methanol with volume of 10 ml ( so that 10 methanol contain 3 unknown concentration ) .The most important analyte to me is ( analyte 1 ) so it was been found that chlorpyrifos compound is the best internal standard for my analyte 1 . But chlorpyrifos is my analyte number 2 !
( the idea is to study the adsorption of the three compounds in five indian red mud , i thing it is better not adding internal standard as analyte number 2 and just spike it not sure i need advice ? )
now i need to prepare internal calibration curve for analyte 1 with chlorpyrifos ( but i thing i cann't add IS to analyte 2 or 3 ? because they are completely different in the property ,so only analyte 1 with chlorpyrifos ) :
what i did ( is it right or wrong ? )
1- 0.01 - 100 mg/L mixtures of the three analyte 1,2 and 3 were prepared in methanol as external standard .
( i've been told after that i must use internal standard so >>>go step 2 )
2- 0.01 -100 mg/L analyte 1 , contain 1 ppm chlorpyrifos in all the standards .
Result of step 2 :
at 0.01 ppm analyte 1 ( contain 1 ppm IS )the peak areas are :
analyte 1 = 7000
IS= 4000
( peak area of analye1 / IS ) Vs. concentration of analyte 1 )
so :
( 7000/4000) vS. 0.01
and i did the same thing for other concentration , is it correct my calculation ? TO make full internal standard calibration
Result of step 2 :
analyte 1 = 7000
IS= 4000
so :
