Multiple peak quantitation in Empower
Posted: Thu Jul 01, 2010 2:28 pm
Hi all
I need to quantitate two known peaks in a single chromatogram using Empower, but could not manage to do. I can enter standard concentrations for two separate compounds, have two separate calibration curves for both of them, but when it comes to entering "sample weight" and "dilution" factors for my samples, I cannot enter weights separately for those two compounds. So when I open the review screen I only see the correct amount for the compound of which I entered the weight and dilution factors.
Is there a way that I can calculate the correct amounts for multiple peaks by entering different weights for each compund? (without multiple processing)
Any help would be greatly appreciated. Thanks in advance
Alper
Alper
