Selectivity changes with YMC ODS-AQ 3µm 4.6x250mm column
Posted: Fri Jun 25, 2010 3:34 pm
I'm new to chromatography and need a little help coming up with a mechanism for the following.
We are trying to develop a separation for 3 very similar compounds using a YMC ODS-AQ 3µm 4.6x250mm Column 120Å [AQ12S032546WT].
The exact structures are proprietary but the only difference between the three is the substituent groups. Compound #1 can defined as [X], Compound 2 is [X-CH2-OH] and compound 3 is [X-CH2-NH2].
At pH 2.5 the elution order is [X], [X-CH2-OH], [X-CH2-NH2].
At pH 3.2 the elution order changes to [X-CH2-OH], [X], [X-CH2-NH2]
The retention time for the [X-CH2-NH2] compound is constant at both pHs, but the retention times for [X-CH2-OH] and [X] increase but at different rates over the 2 pHs.
Can anyone think of a mechanism to explain why the elution order of the [X-CH2-OH], [X] compounds flipped? Why is the X-CH2-OH compound affected less that the X compound from pH 2.5 to pH 3.2?
thanks for any help.
