peak area irreproducibility (sample by loop and valve)
Posted: Thu Jun 24, 2010 4:33 pm
GC HP6890
Note: sampling by loop and valve, not the case of manual injection.
For a given composition of a gas mixture (e.g. cyclohexane in hydrogen, flow rate precisely controlled), peak area for cyclohexane did not reproduce during sequential runs.
To be specific, the area remained kinda stable within an hour or so, but if runs of longer duration were executed, gradual increase in peak area were observed (from 3700 to 6400 after 12 h!!).
In addition, retention time, peak width did not change.
pressure (ambient), temperature (set in the Aux. option) in the sampling loop should remain stable, therefore resulting in a constant amount of hydrocarbon in the sampling loop.
What's wrong with my GC?
