EMPOWER
Posted: Wed Jun 23, 2010 11:18 pm
by Neetz
Would anybody know whether you can assign peak numbers (i.e. 1, 2, etc) to the chromatography obtained via EMPOWER?
I'm trying to streamline my data export processes and where I have multiple peaks I need to have a numbering system so that the data can be picked up by Excel.
Posted: Thu Jun 24, 2010 6:31 pm
by benW
Hi Neetz,
This was an "new" feature in Empower 2. An Auto Peak Label button was added to the components table of the processing method which assigns a number to each of the components.
A work-around for Empower could be to create a custom field to label your components.
However, is it strictly necessary for you to export your data out of a compliant ready package such as Empower into excel? (apologies, you probably have very good reasons - but this always makes me shudder a little).
Cheers,
Ben
Posted: Thu Jun 24, 2010 7:58 pm
by DR
An alternative is to use a Relative Retention Time field of limited precision (ie: 1 decimal place) and have Excel sort peaks by that.
