Sovent Front
Posted: Fri Jun 18, 2010 7:27 am
Good morning all.
I am posting to ask is it possible to determine (as an estimate) when the solvent front should be expected of the column (by only going off the dimensions of the column and the flow rate, i know the dead time of a system would effect this and column particle size but is why i only want an estimate)?
I always thought i knew how to work this out as the equation i was given a while ago is:
((pi x 0.7 x (radius of the column in mm)2 x column length in mm)) / flow rate in ul.
Now i am not sure if this is correct as i cant find any literature with this equation in it.
But for example i have a kinetex column of dimensions 100mm x 2.10 being used with a flow rate of 0.4ml/min
so to fill this into my equation:
((3.1416 x 0.7 x (1.05)2 x 100)) / 400 = 0.61min
As mentioned this is how i have always gone about it in the past but now i would like to know if i am in the right ball park or if i am way off.
If i am way off is there a way to determine solvent front with only column dimensions and flow rate.
I hope this makes sense.
Thank you in advance to all who reply.
Terry
Terry
