Boronate Affinity Chromatography - Help Needed :(
Posted: Tue Jun 15, 2010 12:05 pm
by HydroSpark
Message me please if you have any expertise in this area of chromatography. Solving my problem may result in compensation.
Thanks. :)
Posted: Tue Jun 15, 2010 9:47 pm
by danko
Just a suggestion: It might be a good idea to shortly describe the conditions as well as the problem to be solved. I’m sure it’ll “attractâ€
Posted: Tue Jun 15, 2010 11:28 pm
by HydroSpark
I am looking for a way of retaining the blood sample on a column of boronate beads. Currently the boronate I am using does not retain anywhere near enough of the blood sample on the column before washing. I have witnessed however boronate beads retaining far more of the blood sample on another type of bead which composition is not known to me.
Thanks.
Posted: Wed Jun 16, 2010 2:13 pm
by Andy Alpert
By "blood sample" I presume you mean something like glycosylated hemoglobin (Hemoglobin A1c, etc.). There are two points to keep in mind:
1) All commercially-available boronate materials have a functional group that works well above pH 8.5 but is less effective at capturing glycosylated solutes at lower pH. What pH are you starting at?
2) If you are in fact analyzing glycosylated proteins, then the chromatography material should have a pore diameter wide enough to give them ready access to the interior. This should be 300 Ã… at least and preferably closer to 1000 Ã…. What's the physical characteristics of the material you're working with?
Andy Alpert
PolyLC Inc.
aalpert@polylc.com
Posted: Wed Jun 16, 2010 6:39 pm
by HydroSpark
Hi, I've emailed you Andy. Thanks.
Posted: Thu Jun 17, 2010 8:20 am
by HW Mueller
Too bad that this is going underground.
Posted: Thu Jun 17, 2010 5:34 pm
by HydroSpark
I am sorry, I just wanted to email directly.
Jessica
