Polybasic Peptide with Asp-Gly bond purification problem
Posted: Mon Jun 07, 2010 9:06 pm
Dear Forum,
I am having a problem with my peptide. It is a polybasic peptide (charge +6) with a myristoyl group attached to one end. There is an Aspartate-Glycine bond within this peptide, which I found out has a tendency to self cleave the peptide.
I labelled the peptide and ran it through a semi-prep HPLC column, linear gradient from 0 to 70% ACN, at 1% per minute, all solutions containing 0.05% TFA. My peptide comes off with a nice beautiful peak, labelled as the solution is yellow. At around 79 minutes, it takes I think 10 to 22 minutes to travel the column.
I lyophilized this, then ran it on the column again, same conditions, to see if the peptide had degraded during lyophilizing.
I now see two peaks of nearly equal size, that are coming off 15 minutes apart. I find that the 'yellow labelled peptide' peak is now half the size of what it is supposed to be. (One at 62-64min, and one at 79min)
I do not know how to prevent this degradation. Is it the acidic pH (4.0) thats causing this? Its the only thing I can think of and the literature is not much help.
If I need to buffer it out before I lyophilize, I would risk salts forming in the dried product.
Can I run this column without any acid at all?
Any advice would very much appreciated as I need to prevent this from happening. It is also the only thing standing in between me finish this project and graduating.
Thank you very much for your time,
Sincerely,
P
Sincerely,
P
