Performance of 2.7 um vs 3.0/3.5 Columns as f(flowrate)?
Posted: Sat May 29, 2010 9:49 pm
Has anybody done a comparison of 2.7 um fused core columns with similar phase 3.0/3.5 um columns in terms of separation of a real world mixture as a function of flow rate on a 400 bar LC system? Although I haven't done any formal systematic studies, my experience has been that an Ascentis Express 150 x 3.0 mm column did not perform significantly better than a Zorbax 150 x 3.0 mm, 3.5 um column at 40C on a 400 bar system from 0.4 to 0.8 mL/min. I cannot go much higher than 0.8 mL/min at 40C. Perhaps someone has done a study with shorter columns, e.g. Ascentis 100 x 3.0mm versus an Ascentis Express 100x3.0mm to a higher flow rate? I guess another way of putting this would be at what flow rate would the 2.7 um and 3.5 um column perfomance really start to diverge?
