Trouble with Shimadzu LC-10ATvp
Posted: Thu May 27, 2010 10:32 am
Hello
We have a Shimadzu HPLC with LC-10ATvp pumps. Yesterday I noticed there were synchronous peaks in the baseline. Initially thought air might be trapped in the pump head.
So I changed the buffer to water and purged the system only to notice that Purge function comes on and goes off automatically in about 10 seconds. No errors or nothing. It starts and automatically shuts itself down.
Fearing plunger might be physically broken inside the pump head, I opened both the heads only to find everything was fine, and even with pump heads off when I hit purge, plungers move back and forth for about 10 seconds and then silence.
Being a small university lab we do not have an ACM with Shimadzu. Does anybody have any idea what this might be? May be a small problem.
Regards
mashtikar
Regards
mashtikar
