Experience separating quats on a HILIC column???
Posted: Thu May 27, 2010 4:00 am
Hi all,
I'm developing a HPLC-MS assay for a couple of quaternary ammonium herbicides and am trying to steer clear of ion-pairing agents (TFA,HFBA) by using a HILIC column to separate them.
I've got a bare silica HILIC column and am able to separate both of my compounds but need to use a fairly high concentration of ammonium formate buffer (100mM) to get a decent peak shape and even then there is still pretty bad tailing (posible due to ion-exchange intereactions with silanols??).
I noticed that the ZIC-HILIC column has a different stationary phase with an attached zwitterion and was wondering if anyone had experience separating quats on this type of column.
Stephen
Stephen
