LC pump performance
Posted: Wed Jan 12, 2005 8:30 pm
An HP 1050 LC pump is behaving strangely. When it pumps a 0.2% isopropanol in cyclohexane mix there is a +/- 50+ psi pressure swing. When pumping tetrahydrofuran the swing is +/- 3 psi. Pump has been thoroughly rebuilt (seals, check valve, purged, etc) and seems to operate normally. The IPA/CH mix is run through a de-gasser.
Is there something about the presence of dissolved gases or compressability between the two liquids systems that could explain the pressure instability?
