Sensitivity of lc-ms/ms sysytems
Posted: Fri May 14, 2010 1:12 pm
by shashank_03
can any one tell me which of the following system is best in terms of sensitivity and reproducibility
1)AB SCIEX API 4000
2)WATERS MICROMASS QUATTRO PREMIER XE .
Waiting for your comment
shashank
Posted: Fri May 14, 2010 1:54 pm
by yangz00g
I have used both.
If using reserpine (+ESI) as the sensitivity check standard, they are vitually the same with 4000 slightly higher.
Premier XL polarity switching delay (+ to -) is 20ms vs 700 ms for API. Premier maximum scan rate is twice that of 4000.
API can use shorter MRM dwell time
Reproducibility is sbujective to individual opinion or instrument.
