I have a HP 6890. We haven't used it in months. Status says oven is not ready. When I look at runlog - it states that the temperature should be 45. (Run 1 of 1) I have no runs set up, Rate set to 0. The oven temperature is constantly at 45 even though I have set it to 35. I've run plenty of samples but the run log does not seem to clear. The only way I can get the GC to say that it is ready is by changing my temp to 45. Any ideas on how to get the run log to clear? I do not know much about the GC, I'm just the postdoc trying to get it to work before we call out the big guys. So if you need more information from me, I'm happy to tell you anything I know about the GC and what it is reading or its setting.
Thanks!
