Guide for Mass Spectrometry Identification of Samples Separa
Posted: Fri Mar 27, 2026 3:17 am
This section takes the method of combining nanoliter (nL) level liquid chromatography (Nano LC) with mass spectrometry as an example to explain the method of separating peptide targets using a liquid chromatography column after pancreatic enzyme hydrolysis, and then detecting them through MALDI-TOF-TOF mass spectrometry. The obtained data is analyzed using ProteinPilotTM software to identify the components of egg white matter.
https://www.creativebiomart.net/resourc ... hy-467.htm
