1100 - plate assignments/bottle fillings lost w/ power cycle
1 post
Agilent 1100 HPLC (close to 20 years old); modules inter-connected with CAN, DAD detector connected to PC through G1369A interface LAN card. Quite a while ago, noticed that the plate assignments for the autosampler and the bottle fillings for the pump were not being kept into memory when power cycling the HPLC whereas they used to. There are onboard batteries on the boards in the modules, but it's a bit suspicious that two of them would have died around the same time so I'm just wondering if anyone else has any other ideas of what else I could check; I've already tried cold booting the modules to no avail and I can't test the batteries unless I disassemble the stack and open the relevant modules and would prefer to have the batteries in hand before doing so. I did not opt to do a firmware update at this point since the last updates were performed when we did a major software update and given it was working for years with those versions, I'm hesitant to think that would resolve anything - I'm currently running CDS Chemstation C.01.07 (SR2) and the firware revisions appear to be A.06.10 on the modules (with autosampler having A.06.37). Sort of assuming it's the batteries, but just thought I'd post in case I'm missing something that might end up being less disassembling.
1 post
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Most users ever online was 5108 on Wed Nov 05, 2025 8:51 pm
Users browsing this forum: No registered users and 22 guests
