I’m using a UPLC amino acid analyser with a 17-amino-acid standard, and I’ve recently encountered a problem with my latest runs. In the last few standards, two amino acid peaks are completely missing, while the neighboring peaks appear distorted (“rough-shaped”) and show almost double the expected peak area.
Has anyone experienced something similar? What could be causing this, and how should I troubleshoot it?
Thank you in advance.
