Normal Phase seals for only heptane and EtOH/iPOH?
Hi All,
we do do a lot of normal phase and we have our dedicated systems equipped with normal phase seals. However, I suspect that those are necessary for usage of DCM, MTBE and such. We are looking to deliver a method to a customer who is usually only doing RPLC and the method "only" uses heptane and an alcohol that is also an RPLC solvent - most likely EtOH or iPOH. Are the seals necessary for that combination? I doubt that it is super agressive, since one can even use coated silica columns. Thank you so much in advance for input!
Best
Arne
Probably depends on the exact system. I have a horrible feeling that ethyl acetate and hexane killed Shimadzu Nexera reverse phase seals unpleasantly quickly.
In total there are 22 users online :: 3 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Most users ever online was 4374 on Fri Oct 03, 2025 12:41 am
Users browsing this forum: Amazon [Bot], Google [Bot], Semrush [Bot] and 19 guests
