MS-Compatibility of ion-pairing reagents
Posted: Thu May 06, 2010 4:35 pm
by LCFlo
Dear all,
is octanesulfonic acid ammonium salt compatible for MS?
Thank you
Florian
Posted: Fri May 07, 2010 12:33 pm
by lmh
My experience is that ion pair reagents with more than trivial lengths of hydrophobic chain can be very difficult to remove from MS systems (i.e. expect a background signal of an acidic ion pair reagent to remain visible in negative mode for some time). Use any ion pair reagent with caution.
Posted: Fri May 07, 2010 1:12 pm
by Bryan Evans
I'd recommend looking at different stationary phases.
Below are antidepressants separated on Scherzo SM-C18 (C18 + anion ligand + cation ligand):
http://www.imtaktusa.com/site_media/fil ... TI525E.pdf
Retention for bases (ionic interaction) increases as eluent pH increases.
