I am now try to anlayze the sugar (fructose, glucose, surcose, maltose, lactose and galactose) in food sample.
Apart from using HPLC method, I have found that there are GC method for sugar but need derivatization procedure such as trimethylsilylation.
Example of standard method is AOAC 971.18 Carbohydrate in Fruit Juices – Gas Chromatographic Method.
And, I am trying to follow the method and using GC-MSD for detection.
When I try to derivaztize the sugar individual standard(in solution, and blow dry by N2 prior to derivatization),
I have found there are 2 or more peak for the indivual sugar standard solution.
As mentioned as the following website,
https://sites.google.com/site/masonaco/ ... /gc-sugars
there are anomers of the sugar in form of solution.
As a result, I get a more than one peak (derivatized product) for the single compound.
Are this method is suitable for the quanititaive anlaysis?
If yes, how can I integrate the peak area (sum of the anomer peaks? only the D-sugar peaks?) for quantitation on standard and sample.
By the ways, the MS spectrum for the sugars are very similar and the retention time of the anomer peaks may overlap.
Is it enough for the structural confirmation?
