Normal Phase seals for only heptane and EtOH/iPOH?
Posted: Wed Oct 22, 2025 2:59 pm
by Arne
Hi All,
we do do a lot of normal phase and we have our dedicated systems equipped with normal phase seals. However, I suspect that those are necessary for usage of DCM, MTBE and such. We are looking to deliver a method to a customer who is usually only doing RPLC and the method "only" uses heptane and an alcohol that is also an RPLC solvent - most likely EtOH or iPOH. Are the seals necessary for that combination? I doubt that it is super agressive, since one can even use coated silica columns. Thank you so much in advance for input!
Best
Arne
Re: Normal Phase seals for only heptane and EtOH/iPOH?
Posted: Thu Oct 23, 2025 1:25 pm
by lmh
Probably depends on the exact system. I have a horrible feeling that ethyl acetate and hexane killed Shimadzu Nexera reverse phase seals unpleasantly quickly.
